This command sets or clears the password for level 1 LSPs.
area_name | Specifies the router process to which the password configuration applies. |
none | Disables level 1 password authentication. |
encrypted simple password | Enables password authentication and specifies that the supplied password is encrypted and must be decrypted prior to placement in a TLV. |
authenticate-snp tx-only | Enables password authentication and level 1 SNP authentication. If the tx-only keyword is specified, the password is included in SNPs on transmission, but received SNPs are not authenticated. |
None.
Only plain text passwords are supported. Passwords may be up to 254 alphanumeric characters in length. Although passwords are plaintext in the protocol, they are displayed and saved in an encrypted form.
When password authentication is enabled, received packets are authenticated against the configured password and are discarded if the password does not match. Authentication TLVs are included in transmitted level 1 LSPs with a configured password.
The following command configures the password extreme for areax:
configure isis area areax area-password simple extreme
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
